xterra02_pat
Do you think im underpowering my W7 I def think it could be a lot louder than it is right now because right now I think my 2 15w3's on this same amp were louder. Im getting about 12.2-12.5 volts. I have 2 farad Cap. My sub is wired in Series so its at about a 3 ohm load. Heres the specs I gathered on my amp
Kenwood Excelon KAC-X811D
POWER RATINGS: Maximum Output Power: 1600 Watts x 1 - Power Output at 1 Ohm, at 14.4V (100Hz, 1.0% THD):
1,000 Watts x 1 - Power Output at 2 Ohms, at 12V (100Hz, 0.5% THD):
600 Watts x 1 - Power Output at 2 Ohms, at 14.4V (1kHz, 0.5% THD):
800 Watts x 1 - Power Output at 4 Ohms, at 12V (20Hz - 200Hz, 0.5% THD):
300 Watts x 1 - Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD):
400 Watts x 1 - Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.05% THD): 400 Watts x 1
