Jensen VM9511TS while driving?
Beermakesmehoppy
Is it possible to watch a dvd while driving with a Jensen indash? It has something in the manual where you have to go through a sequence. Can you just ground the wire like the rest of them? thanks
Parking Brake
Parking Brake Inhibit
When the pink "Parking" wire is connected to the vehicle
brake switch, the front TFT monitor will display video only
when the parking brake sequence is engaged. Before starting
the parking brake sequence, the radio must be on with the
video media disc inserted and playing.
Parking Brake Sequence
There are two situations that can start the Parking Brake
Sequence:
• Parking brake is engaged (on) when the vehicle is started
or the accessory/ignition is turned on. To activate video,
the following sequence of events must be completed:
a. Release parking brake for 2 seconds.
b. Reapply the parking brake for 2 seconds.
c. Video should be displayed on the TFT monitor within 1
~ 2 seconds.
• Parking break is disengaged (off) when the vehicle is
started or the accessory/ignition is turned on. To activate
video, the following sequence of events must be
completed:
a. Set parking brake for 2 seconds.
b. Release parking brake for 2 seconds.
c. Reapply parking brake.
it is possible to get a ticket for it too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and all u need is togge switchs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
Vicodin113
