Jensen ATS ATS100rx Amp
Shinju
I picked up a couple of these local, I heard abot them long ago but never saw them.
Anyway This is a stout little amp and pretty well built one too. On the old school side to made around 2001-2002ish
If any of you have used these drop me some feedback I dont have a way to test them untill I get back home from the Holiday's.
Rated at
50x2 4ohm
100x2 2ohm
200x1 4ohm mono
????x1 2ohm mono
Pretty impressive lil amp from the looks of it cannot wait to try them out.
Here are the p0rn shots
Managed to find an acctual manual for these.
Spec's 14.4v (conservative rated expect 20% more)
Stereo
50x2 4ohm
100x2 2ohm
150x2 1ohm
Mono Bridged
200x1 4ohm
300x1 2ohm
THD 4ohm load 1khz .05%
Signal to Noise Ratio 100db below rated output
Fuse Rating 40 amp Maxi
Current Draw 25/70 amps
Tri Mode Capable 1 to 4ohm stereo, 4-2ohm mono
dual channel Gain and Bass EQ dash remote
20 Motorola high current Mosfets for the ats100rx
Size 100rx with end caps
13.5 x 3.375 x 8.75
Fully adjustable built-in Electronic Crossover network
Some specs
EQ gain level 0 to + 18db
Crossover frequency Variable 50-500hz
THD @ 1khz, 1vms .02%
Crossover Slope 12db/octive
I hooked these up lastnight, I have to say these are very impressive amplifiers. I had them running a part of OS Autotek SS 10" SVC 4ohm subs.
Got rather loud for about 400rms. Clean amplifiers. Sucks they have the Jensen name for resale but I can tell you these amps are not your normal Jensen at all..
Cira 1998-2003
I have 2 of them. Not sure what I would let them go for but not on the same cheap price as other jesen amps I"ll have to think about it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Might be up for trades though.
Shinju
Shinju
Seattle
Korn4Life
Mike Mccabe
