I've searched, and read articals. Just need to confirm.
Warrior
WI
Ok guys i've been doing a lot of reading and everything. Well my subs/box and amp came yesterday. The amp kit should be here in 2-3days or so. Im pretty sure I can do this but after reading so much I cant figure out were the in-line fuse goes?
Step 1. Disconnect the negative cable from battery
Step 2. Run power cable to the trunk from the engine (not connected yet)
Step 3. Run the RCA and Remote Wires to the HU from the amp on opposite side of car.
Step 4. Connect the speakers to the amp.
Step 5. Attatch power cable to the battery
Step 6. Attatch negative cable to battery
Turn on the car and hope all goes well?
I would really appericate it if somebody could just lay down some steps like that, or correct me. What tools will I need? Crimping tool? I just cant find any guides out there that are easy enough for me to understand and with PICTURES lol.
Think I got it down alittle bit though....
Yeah that is the part that I dont get. Were am I soppose to put the in-line fuse? What do I do with it? attatch it to the wire somehow? THis is what I am lost on //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
and i know its very important.
Originally posted by Warrior Yeah that is the part that I dont get. Were am I soppose to put the in-line fuse? What do I do with it? attatch it to the wire somehow? THis is what I am lost on //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The fuse goes from the batt, to the power wire. You want it to be about 1 ft or so from the battery. depending on the amplifier, and wire size, you will need a certain size fuse.
Read these pages, they should help you out:
http://www.eatel.net/~amptech/elecdisc/fuses.htm
http://www.eatel.net/~amptech/elecdisc/wire.htm
Warrior
Warrior
WI
Warrior
