IVA-D100 Video Bypass
magewulf
Hello everyone. I recently installed the Alpine IVA-D100. I am trying to bypass the video lock, but to no avail. I have tried the PAC video bypass, and they dont last long. Is there a trick/free way this can be done? I have heard that it can be done with toggle switches. Is this true? Also, I have heard that there is a sequence that needs to be done, if so what is it?
That sounds great, but how do you wire the unit to the switch(s)? Is it the brake wire, the park brake wire, positive or neg., what?????? Sorry I am a little lost...hehehe
yellow with blue strip goes to the red wire on toggle switch (or on position) the black wire goes to ground and yellow and black goes to illumination. now to bypass you must turn the light switch on hit the toggle switch on, off, on and then turn the lights off let me know if you did it if not ill take sum pics of the wires to give you the idea. good luck
yeah turn your headlights on and hit on off on and then turn them off and it will bypass the unit then you can do whatever you want.. it sounds hard but its easy.
Just curious....why the lights? Also, my truck has the automatic lights that come on when the light sensor trips. So before I try this, will that affect this setup?
well i got a 02 yukon and to shut the automatic lights off i hit the dome override 5 times and it shuts it down and it dont mess anything up you do the same to turn it back on sorry but thats the only way so far i have learned to bypass it without that pac
just find a wire with +12 when the key is on.
might work i know it needs the 12v at first but it also needs the 12v taken away thats why the lights work good you can just shut them on and then turn them off, and once its bypassed you can turn the lights back on if you want
So hence, 2 toggle switches so you can turn the +12v off at the end of the sequence?
if you dont want to use the lights i would think that would work fine, just remember the yellow and blue get the 12v and when you done with the switch you shut it off and you done
magewulf
magewulf
Roosevelt, UT
LUV2BHATED
