ISO Amp that does 100 rms @ 4 ohm per channel
You won't likely find a 4-channel amplifier that is 2 ohm stable when bridged. The only thing that comes to mind is some Rockford amps, maybe, but I don't sell RF.
I would sell the MXMA-3001 and MXMA-1502, which would give you 300W x 1 and 100W x 2, for $400. These two amps are very nice Korean built amps that are exactly the same size, so you can put them side by side and not have OCD kick in because they don't match. The controls are under covers on the top panels. I'm discounting them because the cosmetics on these first production run amps are not perfect.
I need it 4 ohm bridged around 250rms and 100 per channel at 4 ohms. So 2 comps at 4 ohm each (100rms) and then both mids in the back be powered by a bridged channel at ~250 @ 4 ohm.
So, 2 components use 2 channels with 100rms per channel. 2 midrange speakers use ONE bridged channel that does around 250rms at 4 ohms for 2 8 ohm speakers.
Wait. Realized that each side of the car might need it's own channel. So I need either 4 ohm midrange speakers for rear or just a new amp for my components. Do rear stage speakers help at all?
Sure, it could be used like that. I also have a p600.5. 4 channels are high only and the 5th channel 300rms @2 ohms.4x 50 Watts RMS @ 4 Ohm Stereo + 1x 200 Watts 4x 100 Watts RMS @ 2 Ohm Stereo + 1x 300 Watts. Only issue, the Saturn logo is missing and the blue LED no longer works.
Savackz
Savackz
GA
ObeyYourRobot
