helotaxi
Kilroy was Here
More port area means lower port velocity which means lower potential for port noise. Port noise indicates a loss in SPL if that's what you're after and it sounds annoying if you're after SQ. There is no difference in how it actually sounds and you either have enough port area or you don't. There are various ranges of not enough from the point where the port is so small that the box behaves like a leaky sealed box to sound correct but having a lot of port noise at high volume. If you are running lower power, you can have less port area without problems. You can have too much port area as well. At that point the port is not able to load the sub and the sub behaves as if it were in free air and there is next to no output. There are trick to allow you to run slightly smaller ports without noise, such as flaring the ends, as well.
