is this safe?
SOUNDz
when installing 2 amps, can u hook up pwr and gnd wires to each and connect the power wire to battery last? the reason being is i dont have fuse and the holder for it yet. so the power wire is justlaying under the hood, but its taped up and stuff though.
i do have one, but the fuses are not in it. if u can imagine that evry wire is connected except for the power wire going to battery.its there, but just not hooked up.wil having this like that, can amps be damaged?, especially when i get fuse holder for battery, and fuses at the dis. block and install them?will power wire from amps have to be disconnected to do this?
You mean connecting all the wires to the distribution block and but connect the main power wire to the battery last:confused: I think thats alright, as long as you have fuses before you connect the power wire to the battery. When your do connect it you might get a spark for like a second but otherwise it should be okay.
SOUNDz
SOUNDz
united states
chaddyc
