Is this possible???
you mean split the power wire from the battery to each amp? that just calls for a distribution block. theyre about $25 at bestbuy. im sure you can find for cheaper.
you would need another set of RCA wires so long as your head unit ahs another set of outputs. The remote wire can be easily daisychained, just run to the second amp from the first one, but new RCA's will be necessary... unless it's a second subwoofer amp. if it's a second woofer amp, you can daisy chain RCA's if the amps ahve RCA outs.. if not, tehn you need Ysplits..
about your first ?, you can use a distribution block if you ain't running two massive amps that each need a 4 guage line with to massive amps i would probably run like 1 or 0 guage wire to a big distribution block, i don't really no what the cut off is so if you let us know what amps your running maybe someone can answer your ? more accuratly.
94preludesi
94preludesi
Fayetteville, Ar.
Wonderbread
BP1Fanatic
BP1Fanatic
