is this possible: clipping detection using a dmm?
Clipping IS NOT DC, it's still oscillating, so it's AC. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i know now, check the edit of post 7 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I don't think I've ever heard the term "power compression" used in reference to an amplifier before.
But the essence of what Hoss is saying is right.....eventually you'll reach the rail voltage of your amplifier and the voltage will cease to increase any further.
I certainly would not use this as a method by which to set gains or determine the level of acceptable distortion, however.
Me either. But I'm aslo not half as knowledgable as some of you guys on here.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
But this is what I found on jbl's site as far as power compression goes. Not much, but gives you an explanation as to what it is.
http://www.jblpro.com/pages/general_faq.htm#What
Already been covered.
//content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
well currently i just use the standard dmm, test tone procedure as i dont have access to an oscilloscope anymore.
i was just trying see if there was maybe a different, and better, way of going about it.
Either by ear, or with an O-scope.
Those are pretty much the only options currently.
You could also try using different level test tones (0db, -3db, -6db, etc) & the DMM method.
thch on here a year or so ago was thinking about making a little project that would have an LED light bar denoted with levels of "distortion" (1%, 10%, etc) IIRC......don't know what ever came of it though.
yup, i remember that thread.
yea, im satisfied with my output (i use -6db for subs and -3db for speakers), so thats not an issue. just a little thing that popped into my head.
I would not use the method of power compression to determin clipping. In most amplifiers I have benched on my scope clipping starts well before the voltage stops increasing. For example on my xxx-6500 clipping starts @77.2vac, but the amp is able to reach 99vac before the voltage starts to taper off.
IgnoreMe
CarAudio.com VIP
IgnoreMe
caraudio.com
squeak9798
