Is this ok for big 3?
ItsAJeepThing
As I was working on my big 3 I found out the wire running from the alternator went to my fuse box then a separate wire went from the fuse box to the batter with a fuse in between. I got my grounds replaced without an issue. I just went ahead and left the alternator wiring on but added a piece of 1/0 from the alternator directly to the battery. Is this ok or is there a better way to approach this? Everything seems to be working fine. I made a diagram of what I am talking about and will post it.
Id bypass it since it wont allow for bigger ga wire. There was a thread a few weeks ago that someone had done that and could only fit 4 ga. I would bypass the stock fuse block and just use an inline fuse.
Edit: That is fine to leave the wire still there the current will take the path of least resistance.
Dont do that. If your going to do a big3 upgrade you need to do it right. That means 1/0 gauge from the battery to the alternator. 1/0 gauge from the the battery to the amp. Both positive and negative leads. 1/0 gauge from the amp negative to the grounding location in the car. or if you just want to use the chasis as a grounding point it needs to be no longer than 3 feet, and it has to be grounded to a solid chasis of bare metal.
Big three is also upgrading the alternator and upgrading and/or adding extra batteries.
I hope you dont fry your car.
this is correct
the fuck are you talking about? the big three is:
-upgrade wire from battery + to alternator +
-upgrade wire from battery - to chassis ground
-upgrade wire from battery - to engine block grounding point (or alternator - if you feel so inclined)
it has nothing to do with extra batteries or alternators...
ItsAJeepThing
ItsAJeepThing
Lincoln,NE
ItsAJeepThing
