Is this even possible?
pervertatoid
Is it even possible to create a vented box which will hold four 10" subwoofers that will also fit into my trunk? The box could be no more than 18" high, 36" long, and 24" deep. I can't figure out how I'd mount all four subs on a 36" x 18" face, more or less a face that would be smaller due to a vent...
Any suggestions?
Could always put the port on a different side. While it's repeated a lot that you're "supposed" to have the port on the same plane as the subs, there's nothing that says you can't experiment with different configs...
I doubt it... after you figure in the sub and port displacement, you aren't going to have much room. sure they can probably fit, but i'm not sure if there will be enough airspace. what kind of subs you thinking of running?
pervertatoid
pervertatoid
Colorado Springs, CO
helotaxi
