Is this correct or no?
dirtbagz89
dirtyTHIRTY
I found this companies website that sells amps...they explain how to determine if your vehicle's alternator can provide adequate current to the amp.
http://www.quantumaudio.net/amperage.htm
Now using what they say my setup would be like this:
2008 Pontiac G5 stock alternator = 105 amps
105 divided by .40 = 42 amps available
Amp current demands:
Keep in mind I am looking into buying 2 Dual 4 ohm 12" Alpine Type R subs... both are 500 RMS for a total of 1000 RMS.
Now I have a couple amps I'm looking at...my budget is about $200
http://www.sonicelectronix.com/item_11795_Kenwood+KAC-9104D.html
900 watts wired at 1 or 2 ohms...so 900 rms divided by 1800 peak is .50 (50%)
Fuse value on amp = 30a x2 = 60a
60a x .50 = 30 amps
http://www.sonicelectronix.com/item_8177_Kole+Audio+KX1-2000D.html
900 watts wired at 2 ohms...so 900 rms divided by 2000 peak is .45 (45%)
60a x .45 = 27 amps
http://www.sonicelectronix.com/item_8403_Kole+Audio+KX1-3000D.html
900 watts wired at 4 ohms...so 900 rms divided by 3000 peak is .3 (30%)
Fuse value on amp = 30a x3 = 90a
90a x .30 = 27 amps
So is this website correct or no? So I would be alright buying these amps using my stock alternator?
I get the basic info, but I don't see how, say a 600rms amp, with a fuse rating of 60 amps only has a 30 amp or so continuous current draw.
I was two amps, with a combined fuse rating of 100 amps, roughly 1000 rms, with a stock ~65 amp alternator. The 6th gen Civics, and some newer models had a tiny *** battery. My CCa rating on my battery is 425A or so. I was getting head light dim, then I did the Big 3, but not my alt to battery wire, because it's a b1tch to get to my alt. I then upgraded to HID headlights, and lost the headlight dim, but the interior and gauge lights would sometimes dim a little on hard notes, but my voltage never went below about 12.5 volts at idle.
I think you'll be fine. Do the Big 3, and get a bigger upfront battery with a high CCA rating.
Music has a duty cycle.. even a bass amp that can pull 100amps of current is only going to average 20-30 amps..
A good rule of thumb is divide your alternators output by .33 and that is the maximum amount of current draw your alternator/battery is going to be able to keep up with...
105/.33 = around 300 amps...
dirtbagz89
dirtyTHIRTY
dirtbagz89
Buffalo, New York, United States
Haunz
