Is this an SE or HC?
SirSyko
Delusional Psychotic
I recently bought this sub from ebay saying its a 15" HC. It sat for a while in my house cause im waiting for an amp and deck. During this time I installed my bros entire system including a 12" HC with the **** dustcap. I did not get to directly compare them but for some reason his magnet seamed bigger even though I knew my cone is a 15" So basically my question is how to tell an SE from an HC, thanks.
That is a 15HC. I should know since I have 2 of them. The magnet on the SE is much smaller and the 15HC weights about 45-50lbs while the SE is less then that.
The reason his magnet looks bigger is probably since his was a 12 inch. They all use the same size magnet so it will appear bigger on a 12.
Thank you very much, that is the answer I was waiting for.
ill buy it off you
Lol, I havent even had time to play with it. It has only seen 200 watts from a fosgate amp for a couple days until I sold it. Now its all hooked up and Im waiting for the deck. Why would you want to buy a discontinued model anyway?
Yup looks the same as my HC's.
On my digital scale my HC 15 weighed 40.2 lbs so if yours is about there, u are good to go.
Definaltly though, a motor on a 12 inch basket looks decevingly larger than on a 15 or 18" basket.
PS the HC's are great subs //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I have 2 in my car and 1 sitting on the floor in my room lol
Craig G
Like Kurt said, big *** top plate on the HC...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dude...don't seal it!! 3.5 cubes net ported...do it. If it won't fit, make it fit.
SirSyko
SirSyko
Vancouver, WA
Bavarian3
