Is there any difference running 2 or 4 ohms?
funkdoktor
i have an amp that can push 1000w rms in 2 and 4 ohms...is there any difference between the two?....will the amp perform better running in 2 or 4?.....(i mean better like run cooler, more efficient...ect.)....thanks guys.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I would run it in 4 as opposed to 2...
like the above said, less strain on your electrical system
also when you drop ohm loads on amps, it might increase the % of THD that amp puts out, while normally its still 1% or lower so you probably won't notice a difference in sound... its still worth mentioning
interesting....so 4 ohms...less strain on electrical system....hmmm....thanks guys...anybody else got an input to this convo?...
Someone else might have some more input, but what else do you need to know? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Strain will be the same for an amp with regulated supply. The only possible thing that can be bad for a regulated amp running on high impedances will be stress from it trying to increase voltage of supply high enough to compensate for the resistance P = V*I = V^2/R => dV = sqrt(P* dR). But it's unlikely.
THD really can change even with regulated supply, but it's hard to predict how, as it will depend on particular design. I would personally run it on 4 ohms, it might be easier on outputs.
funkdoktor
funkdoktor
honolulu, hi
funkdoktor
