Is my factory alternator enough?
Only one way to find out. Stock alts are rated at max and at a high rpm we never see under normal rpm's. They are designed to power all the accessories and then some but not a whole lot.
If you have enough reserve it will be fine but if you get flickering lights thats a sign that your electrical can't supply enough power for the demand.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
900
C-LocJiggleNuts
CarAudio.com Recruit
C-LocJiggleNuts
Seattle, WA
2RZ-FE
SlugButter
    May 4, 2024
slater
    May 2, 2024
