Is it True?
i don't know bob, i think if you put a btl in its optimum box and power compared to a funky pop with its optimal box and power, you just might hear a difference
but if you have say a old school XXX and a Q, most people may not be able to tell the difference...
yes and no...
yup.
I heard that i dosent really matter what woofer you get with the right set up and power you wont really be able to tell the difference between two different subs.
not to sound elitist or above you, but this is kind of one of those questions where if you have to ask, then the answer is yes. and allow me to explain what i mean...
im assuming you dont have alot of listening experience. with that in mind, then you will most likely, most probably not notice a difference. there might be a difference in output, but again, marginal to most peoples ears. some people may be able to note a difference, but for alot of people will not be able to.
i think you mnis unde4stood what was being told to you.
if you take a cheap woofer and properly install it and put it up against the best sub in a carppy install the cheap sub will end up being better
DatBoy420
I Got A Brick
DatBoy420
Pensacola,FL
creyc
