crossfire2k5
If I had 2 subs on either side of the trunk and they were facing eachother, would that be ok?
its alright to doIf I had 2 subs on either side of the trunk and they were facing eachother, would that be ok?
it is called isobaric loading, but not in this case. If the subs are on opposite sides of the trunk and you wire 1 out of phase, that is call having 1 sub wired wrong. Trust me, there won't be much output. Isobaric is for subs to fire 'push-pull' in a small, sealed area and does not apply here.Yep, it's called isobaric loading, and it will work as long as you reverse the polarity on one of the subs, so when one fires outward, the other fires inward.
here are some examples of ISO loading.
http://www.the12volt.com/caraudio/boxes4.asp
true. I was referring to the common 'clamshell' setup, which I use in my daily box.//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gifIsobaric loading is not always a push-pull affair. Two identical drivers mounted one directly infront of the other or behind is still an isobaric type, but not push pull. Sure you knew that, but just wanted to clear it for some others.
I've seen it done, it might cause some cancellation issues though- not 100% sure though. That is why I chose not to do it that way.
You will probably have cancellation problems.
sound = pressure. wire one backwards and you get no pressure.wire one out of phase...
Not exactly true. Wire one speaker out of phase from the other and you will still get sound, it will just have all sorts of cancellation issues (based on frequency, distance between subs, etc). Speakers do not create sound from pressurization, they create it from sound waves. The pressurization is a byproduct we measure to gauge instensity.sound = pressure. wire one backwards and you get no pressure.
And how are sound waves created? Through the pressurization and rarefaction air.Speakers do not create sound from pressurization, they create it from sound waves.
