mscott1979
wat up peeps? i have a question that i've tried to thread-locate but i cant seem to find the direct answer im looking for. I have an AQ 4 channel and AQ monoblock that i recently mounted in the trunk of my car along with a 2nd optima battery and i decided to ground both amps to it. I instantly got a little bit of alt whine from the 4 channel and it's running pretty hot now, well in my opinion above operating temp. When i had them mounted to my back seat (which stayed folded down all the time due to the size of the monoblock) Neither amp got hot just warm enough and u could lay the palm of your hand on either and leave it there if that gives you guys an idea. Both where grounded to the chassis and i was wondering should i ground them where they were before or is it that my trunk is just holding heat around the amps and causing them to run warmer than usual?
