Is a Rockford Fosgate P400-4 1 ohm stable?
actually, Fosgate doesnt "advise" that any punch amps are one ohm stable..however, just today I witnessed a 400.4 run at 1ohm and not cut out. Advisable? No.
Possible? Absolutely
now, let me clarify..i may have seen a 400.4 do 1ohm stereo, not 1ohm mono. Is there a difference? Of the 4 channels, 2 of them were bridged to a dual 2ohm sub wired in paralell (one ohm). Being that only 2 of the 4 channels were used, would that create a 1ohm "stereo load"? or is it still mono because 2 of the channels were bridged? I think 1ohm stereo would be if only 1 of the 4 channels saw a 1ohm load?
And as to blowing up, My buddy drives around his daily driver like that, and it has never cut out. But maybe being that only one side of the amp is seeing 1ohm, is helping?
Like i said, Advisable? Not at all...Possible? Yes
It is not 1 ohm stable. It's a class a/b hybrid. The BD series are 1 ohm stable. And yes, bridging is mono. If you wired the dual 2 ohm coil in series it would be 4 ohm, then bridge the amp which brings it down to 2 ohm. Don't run the coils in parallel. Even then, four channel hybrids typically are not 2 ohm stable either. 2 ohms you could probably get away with though.
yungstarter
yungstarter
California
kr15
