Is $973 to much money for wiring?
Only company I have found in the Online Stores I look at... If you have a site with pricing from other brands you are welcome
Knukoncepts.com can sell you everything but the battery. I would pay the extra for the Ultrafleks 1/0 wire. I got my 14/2 speaker wire and the Konfused block from them. You don't want to get stuff from ebay stores?
Thanks a lot too all specially to Ali1, now I have lowered the price of wiring to $793!!!!!!!!
1 Stinger SP1700 $399.00 $399.00
40 Kolosus KOL1/0S $3.25 $130.00
1 Kolosus KRY4.4M $24.99 $24.99
1 Kolosus KRY2.4M $16.99 $16.99
2 Stinger SPD5204 $26.00 $52.00
2 Stinger SPD 5210 $29.99 $59.98
10 Kolosus KOL8BL $0.65 $6.50
1 Kolosus KLE12BL-100 $49.99 $49.99
2 don rowe ANL 400 $15.00 $30.00
2 Kolosus ANL 250 $5.99 $11.98
2 Kolosus ANL 150 $5.99 $11.98
$793.41
you won't be dissapointing with the Kolossus, awesome wire and won't look back if i had the money. As for the battery choice, look into the powermaster d3100 instead of tha SP1700. Far more reserve power and capacity. Do a search on those batteries, they are beneficial in daily systems and SPL events.
" I would put the new XS Power Group 34/78 D3400 with iBars under the hood. It will fit, as Powermaster adheres to group sizes in their larger batteries. The D3400 is good for 2500 watts as a primary battery and 4000 watts as a supplemental battery near the amps. ( given proper install, of course )
The Kinetik HC2400 is only good for 1700 watts primary, and 2600 watts supplemental and costs more than XS Power. The construction is all the difference.
Both XS Power and Kinetik will be easier to charge and keep charged. . so factory alt or not .. they are better than yellowtops.
If you still need more juice, the D925 is a great small supplemental battery near your amps. It's good for 2400 amp bursts / 2000 watts supplement.
http://www.xspowerbatteries.com
Notice Alan Dante, Scottie Johnson, Steve Meade, and Tommy Mckinnie among many other win using Powermaster "
Apparently, the d3400 hasn't came out yet, so you will be pleased with the d3100.
http://www.jegs.com/i/Powermaster/713/D3100/10002/-1
I bought mine from there. came quick and no hassle
I hate the KNU Kolossus wire b/c it's oversized... won't fit in to accessories such as fuse holders and ring terminals that are made for standard 1/0...
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Also, their twisted speaker wire is THE WORST to work with EVAR.
The FLEKS power cable is great though.
nG
nG
this is true, but i've used their distro blocks and they seem to take most of it in...
maybe aim for 0/2 blocks?
$400 for that battery is too much. You can find better for less as has been mentioned.
You also don't require a fuse on your ground wire. It's ground. If it melts or touches metal it's just grounded and nothing will happen. You only need to fuse positive runs.
was just going to say the same thing, they had the 2400 at a shop around here for either 350 or 399
asisrem
asisrem
Mexico City
donpisto
