iraggi or Excessive Amperage?
also i need your opinions on these specs..of these alts which would you go with for a 4000 watt system..
300amp/135 amp idle
280 amp/145 amp idle
260 amp/155 amp idle
i got a 280 amp from iraggi. hes hit or miss. ive had great luck with him, no problems and actually been able to contact him, but i have friends hes screwed over too
I have one from EA and it's got shit for amps at idle, my stock alt puts out twice as much as the high output one from EA. The customer service is great and the prices are pretty good, but the alt is useless unless the rpm's are at 2000. I had my 200 amp alt tested and it was putting out 30 amps at idle, where my stock one puts out 60 at idle. I only put it in before I hit a show, and then it's only worth it if I can sit inside and rev the engine during a run.
Why havent you talked to ea about that?
I had my EA in my old Pathfinder for around 2 years without a problem. I actually ended up blowing it, but that was due to it being nearly submerged in water (Nissan decided to put the alternator underneath the engine). 'Twas a good alt, though. Never got it tested, but ran a ton of power from many different amps with no problems.
denalilvr
just laugh
denalilvr
illinois
snoopdan
