Inverted?
it doesn't matter if you're using 1 sub, but if you are using more than 1, they all have to be facing the same way or you'll have to change the polarities of either one to match the phase of the other.
you must switch polarity once a sub is inverted
if you have vented enclosure your tuning might go down a hair
people do this to show off the sub's backside or because the want to give the sub more space
u do not have to change the polarity if you're using only 1 sub inverted. you only have to change polarity if you are using more than 1 sub where there is a mixing of inverted with non-inverted ones.
hmmmm...
I guess it depends on your install, I read differently.....
http://forum.elitecaraudio.com/showthread.php?threadid=113925
http://forum.elitecaraudio.com/showthread.php?threadid=72553
http://forum.elitecaraudio.com/showthread.php?threadid=100662
http://forum.elitecaraudio.com/showthread.php?threadid=28208
http://forum.elitecaraudio.com/showthread.php?threadid=91346
http://forum.elitecaraudio.com/showthread.php?threadid=42063
"With only one sub you can wire it in or out of phase. Theoretically, if you wire an inverted sub in phase, it is out of phase. In car stereo it doesn't matter much because we wire subs out of phase alot of the time anyways. Just remember this, if your sub is inverted its cone is moving the opposite direction it would normally be moving. So if you do mount one inverted and one normal they have to be 180 degrees out of phase with each other"
great quote by Jimi77
NewToTheGrounds
NewToTheGrounds
Canada,ON
phantom240
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
