Installing flared aeroports?
I havent even decided where im getting the ports. Ive seen precision ports but dunno if thats what i want. What do you suggest?
The precision 6" ports (when they are officially available) will probably be your best choice. They have nice mounting flanges with screw holes that are easy to mount.
But the homemade ones are pretty easy to use as well. You just have to get some large-headed screws and set the screw on the edge of the port. When you tighten the screw down it'll grab onto the edge of the port and hold it in place.
On topic question,.....When doin extrenal aeroports do u need to mount it inside the box or can u just screw it to the outside?
And does that usually yield better number,proven?
On topic question,.....When doin extrenal aeroports do u need to mount it inside the box or can u just screw it to the outside?And does that usually yield better number,proven?
Try out both ways and see which one works better. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sometimes mounting internal yields higher SPL, sometimes not.
I've tried both and yield higher SPL numbers and lower bass by using slots.....And numbers don't lie //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'm the opposite. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Though i don't go for "lower bass", just higher SPL numbers. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
My numbers don't lie either. (numbers in sig in case you didn't notice //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif)
tommyk90
THE WHOLE THING!!!
tommyk90
Chicago Heights, IL
supa_c
