>>SQL<<
I am pulling the rear deck trim off right now in order to remove the crappy 6x9s that are mounted in it. I thought I would put some fatmat down while I have everything off.
1st question is does putting some deadener on the rear deck even needed?
Perhaps I should put it on the backside of the deck trim as that is what would be more likely to rattle, right?
Also temps are about 40ish right now. I have a heat gun. Do I heat up the sticky side of the fatmat before putting it on or do I put it on and then hit it with heat from the top of it?
thanks
thanks
