Installing Comps Please Help !!
It has two sets of inputs and two sets of outputs, the crossovers bi-ampable. I don't want ot run it as bi-amp I just want to run it regular. Which inputs do I use? Do i just use the positive from the woofer and the negative form the tweet?
u should have an out for tweeters, an out for mids AND a low pass input and a high pass input too
if you are not going to bi-amp then use the low pass input to connect to your amp
hope it helps
profoundwill
profoundwill
Birmingham, AL
metalmilitia
BP1Fanatic
BP1Fanatic
