Installing Amp into Factory Head Unit
seahchenshian
CA
Hi, I am trying to run my amp on a factory head unit from a chevy silverado 03'
04 model. My setup will eventually be 2 front and 2 rear speakers running off
the head unit while I have 2 subs running off a 2 channel amp. I know that the
factory head unit has no connections at the back to support an amp. For the RCA
wires I would need to get a converter to convert the speaker wires to send
signals to my amp. I am currently having 2 problems right now, I am not sure
about the RCA converter and the remote turn on lead.
First question, the RCA converter.. Would i be able to strip a small part of
the speaker wires and run a wire from that exposed wiring to my converter so
that the wire from the head unit to the speakers would still power the
speakers. I am not too sure if the converter means that I would have to
sacrifice having the speaker wire power the speakers? Or can I have both, tap
into the wire to run into the converter to have a rca jack while still allowing
the speaker wire still powering the speakers.
My second question is.. the factory head unit has no plug for the remote turn
on lead. Where is a good place to get a 12v current to complete the circuit to
turn on the amp. I am new at this? I heard and read that you can tap into the
ignition wire but I am new at this and I have no idea which wire is which and
where to find them or how to get to them. let me know how to get the remote
turn on wire working.
Thanks alot.
for the remote wire you could use an ignition wire but it would be easier to use the same acc wire your factory head unit uses. if yournot running an amp for the front and rear speakers you could just use a splice to get the wires hooked up to the converter. But if you plan on running an amp for the front and rear speaker then you would only use the stock wire for the signal to converter.
you can connect the converter and the speakers simultaneously ...tip... connect the
converter to the rear speakers so you dont have to run as much wire, also for the remote
lead just connect it to the fuse panel, just find a wire that gets power when the ignition is
on, that way you don't have to cut up the factory wiring.
Decipha, why do you have that in your sig?
You remind me of them **** girls in high school who would put shit like that in their AIM profile to make themselves feel better.
Hope you don't sprain your arm patting yourself on the back!
seahchenshian
seahchenshian
CA
Atomic
BP1Fanatic
BP1Fanatic
