Installing Alpine F250 amp
Hi guys,
I drive a 04 TSX non navi
I've just installed a sub and a mono amp. I am going to switch my stock front speakers to alpine type S. Also, i got an Alpine F250 amp to install too. I have no idea how to hook up the 4channel amp to my front and rear speakers (4 in total) Can anyone give me some instruction? hints? links?
Also, I've used 4AWG power wire for my mono amp. I am planning to use 8AWG for the 4channel amp. Do i need some kind of battery terminal like this?
Last Q, i need an inverter for my carputer. Right now i'm using the cig lighter type of inverter. however, i want to move the inverter to the trunk with all the audio stuff. What size of power wire should i use to power up the inverter?
Sorry for the many Qs. Thanks in advance guys.
Get a (fused) distrobution block so you can split the 4awg wire you already ran into 8awg, then run each into your amps. How big is your mono amp? Model name? You dont need a battery terminal.
Are you using the stock radio? How are you getting a signal to your mono amp?
Click the link in my sig. :eek:
penny1jordan23
penny1jordan23
Vancouver
penny1jordan23
