installatin question for amp power and speaker wire size....
buckeyechad1974
thx in advance to any help offered!!
what size power wire do i run to the amps?? i assume this is ran from the battery to the amp? i have a second amp as well.....do i run 2 wires or can i wire from one amp to the other? the amps i have are pioneer gmd9500f's. the amps have fuses in them....do i need to install an inline fuse as well?
what size wire do i run from amp to 6x9's?? will be carrying 75RMS watts.
what size wire do i fun from amp to 10" subs? will be carrying 225RMS watts.
what kind of wire do i use for the system control from the HU to the amps??
is there a specific RCA wire i should run from HU to the amps??
THANKS A MILLION!!
ummm....you should check out the stickies in the forums
but being brief, run 4ga power from battery about 6-12 inches, inline fuse it, continue the wire to your amp location and run it to a 4in/2 8ga out distro block. Run the 8ga to each amp. 14-16 ga is fine for your 6x9s and 10-12 is fine for your subs.
Run your remote and your RCAs to your amps. If you dont have 2 sets of RCAS, you will have to daisy chain your amps using the small jumper RCAS, they are ususally about 3 feet.
buckeyechad1974
buckeyechad1974
arizona
kr15
