Infinity Perfect 12D VQ inserts ???
if it's brand new, i THINK there's a piece of paper that shows the best boxes for each. If not, try googling the T/S for each plug and we can help.
No papers, I did a little search but its all in AUDIO language...I am still learning! I need it in plain ENGLISH...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused:
I already built a box up to specs. I just now need to know which insert to use!
right. post the numbers and someone will plug the numbers in, that will tell you which one comes closest to your box specs.
i can't remember which is for which:crap:
use low. page 6, first chart, second section. Your box is between line 1 and 2 of the second section. you are on the small side for the proper box for that sub.
Yeap, I just read that. Thats what I have in it right now. Thats for your help.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if you built a box to spec than you don't need to use an insert. the only real use for them is if you have to use a box that is below spec. it helps the sub work in a smaller enclosure. but like i said, if you have a good box you don't need any inserts.
Raffi
Bring our TROOPS HOME!!!!
Raffi
Orlando, Florida
sue bee
