Sold Infinity 1250w 12" and Insignia 380wrms amp custom painted
skydeaner
suede humper
I'll start with pictures just to be different
Everything should be considered in like new condition 10/10 cosmetically and operationally.
The insignia amp i was pleasantly suprised with. I would say it really does do it's 380 watts bridged 4 ohm rms with ease. No weird sounds or turn on pops or anything. Really decent performer. Here is the specs:
RMS power 13.8VDC
Power 4 Ohms............................... 120W 2
Power 2 Ohms............................... 200W 2
Bridged power 4 Ohms ................. 360W 1
Minimum speaker impedance.............. 2 Ohms
THD distortion....................................... 0.08%
IMD distortion........................................ 0.08%
Frequency response............................. 20 Hz to 20 KHz
Input sensitivity..................................... 200mV to 6V
Input impedance ................................... 15K
Signal-to-noise ratio............................. 90dB
Channel separation............................... 50dB
Crossover network
Low pass filter.................................... 45 Hz to 300 Hz
Bass boost......................................... 0dB to +12dB
High pass filter................................... 45 Hz to 300 Hz
Fuse rating............................................. 20A 2
Size L W H ....................................... 15.67 10.16 2.56 inches
It was kinda beat up when i got it so i hit it up with some sand paper, then primer, then black / red paints, sparkle clear and then regular clear coat, then wet sanded and buffed with polishing compound. The finish is really prett nice. Better than i expected it would be.
The infinity isn't a bad sub at all, handles a decent amount of power, all though i never had it matched up to anything that required it as i have been running only rear stock speakers for a while now since i sold my ads comps. So it has been run very lightly.
Specs on the infinity 1250w
Peak Power Handling 1200Watts
RMS Power Range 300Watts
Impedance ( Ohms ) 4
Free-Air No
Dual Voice Coil No
Sensitivity 93dB
Frequency Response 23 - 40000Hz
Cone Material Polypropylene
Surround Material Rubber
Dimensions
Sealed Box Volume (cu ft 1.25
Ported Box Volume (cu ft) 2
Top Mount Depth 5-1/8"
Cutout Diameter or Length 11-3/16"
Size 12"
50 bucks each + shipping. Shipping in 48 conus for the amp will be 10 dollars, the sub will vary with location because i can't fit it in a flat rate box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Contact me at skydeaner@gmail.com or pm me.
Im interested in picking that up for a girl who wants a starter system...
how much would shipping be on both of them to 99337 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
skydeaner
suede humper
skydeaner
Champaign, IL
skydeaner
