Infiniti Qx4 (4) 15's Wall Re-Do. (Im bored log)
are you doing more then 1 layer? because in my build I did 3 layers tons on glue and screws and yesterday i noticed the back of my box is moving enough to break loose the seam. so i now have 2 1" gas pipes from front to back and large 45's (17' wide) going from the side to the back and yes it did make a difference on the mic and to ear
dam 17 ft. braces???
Itll be about 16sqin / cube.
I havent gotten dink all done though, I need help on how tot une this weird shaped port I dont understand how to figure the length, and its been raining CONSTANTLY for 3 days straight.
I did however pick up the gallon of fiebrglass resin and 16 meters of 3 oz chop mat (obivously im not gonna use it all but it was dirt cheap so I bought most of what they had lol
Ill resin up the corners and sides of what I have done for now
Got a decent bit done today, rushed home no lolligaggin and prayed the weather would hold up, it started raining a few times and I had to bring everything inside, but it always blew over, ran out of light before I could get done though.
I started out by throwing 3 layers of chop mat on the angled wall and back wall joints, I felt those were my weakest as I couldnt screw/clamp them amazingly well during assembly. Also made a few braces out of 1 1/4" cedar, just to keep all the walls in check.
I know it aint pretty with the dripping, but Ill scrape it off when its dry, its the inside anyways who cares.
(I did this brace on both sides of the box, forgot to snap a pic of the other I guess )
I then realized I was not going to be able to fit the front baffle in with the port attached to it like I wanted to, so I broke the baffle into 2 pieces, so it could all be assembled and glassed in the garage
Decent circles for a broken jigsaw
Test fit in the car, not glued or screwed
SO then I ran outta light, I just finished glassing the baffle pieces though.
Tomorrow when I get of work I will smooth out the inside of the box with some 30 grit, attach the front baffles, and then glass the entire box, then smooth again and go over it with bondo (atleast the part youll see behind the port)
If i have time for beauty panels Ill make those to. I still dont know if Im simply gonna texture paint this entire box, or carpet it and just texture the paint the port
Time to watch the hockey game
ya i still dunno about the port.. but we will see.. keep us informed on how it sounds
yup im skeptical //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
but its not my setup //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ya it took me 3 days and $30 worth of payouts to get some help from some designers on the port length and design.
It is tuned to 40hz on the money if there calculations are right, I finally got 3 people to give me the exact same answer, so Im pretty sure its right
Im gonna spend a decent ammount of time trying to get a nice roundover on the port
Im going to spend my lunch roaming through town to find some textured paint and fabric to cover this *****
Not a single store that I can think of in my town carries flexstone/rough texture paint.... all I could find is bedliner, but I wanted to do a colour...
I may end up making my own paint with grains mixed in or something lol
Oh well, back to work for the man
Well aparently i had dinner plans witht he lady tonight, so progress had to wait until AFTER dark, since i was only working with trouble lights, I only got the 2 baffles installed, glued and completely fiberglassed in, then I fiberglassed all of the seams of the box.
Also mounted and completely wired both of the amps, (looks pretty tits to)
SO tomorrow all I have to do, is smooth the port, paint it (decided to go with rocker guard black (sicne I have 2 cans laying around lol), make the 3 beauty panels, mount and wire subs.
DONE
Oh, and clean out the car, shit is DUSTY from doing all that work inside of the rig
WOT
Banned
WOT
Toronto,CANADA
SWFL
