In line volume control
  • 2
bherron1985
Need help with this one. I am using one 4 channel amp (2 ch. to speakers and bridged 2 ch. to sub). I would like to be able to turn the volume down to the sub only, when desired. The in line volume controls I’ve seen all use RCA connections; however, the output of the bridged channels are speaker wires. Any thoughts on how to introduce a volume control in line for the sub only? I’ll be using a Bluetooth receiver, which only has one female RCA output. Thanks in advance!
welcome to the forum!
use a PAC LC-1 https://www.amazon.com/PAC-LC-1-Remote-Amplifier-Controller/dp/B0002J226O
rca in from the source, rca out to the amp, attenuate from the knob
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
937
bherron1985
bherron1985
youdoofus
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
