Im such a dumba$$
Wkbdkid
i was bored today so i thought i would go out and clean up all my wires and make it look good(jus installed comps). So im winding up the wires and everything is going fine. Then i start on the power wire for my comp amp and i drop on accident, and knowing my luck the terminal lands on a fuHas anybody else made any dumb things like this before?
I was free-airing some type-r's after I reglued the surround on. I wired one up, it worked fine, then wired the other up and it didnt work. So I said screw it, its old, i'll just get a new one. So i started striping a lamp cord to give it its send-off to woofer heaven when my friend who knows nothing of car stereo wiring says "Hey isnt it positive to positive, not positive to negative?" Confused, I looked over the wiring and sure as shit, I had it wired wrong. I about blew up a perfectly good woofer, lol.
I dropped a power wire on my old profile amp and friend it lol.
You live and learn.
I keep trying to tell Blaze06us that he needs to unhook the main fuse before he puts his new amp in. He says you dont have to do it. So ill let him learn the hard way.
He said he has unhooked his current amp several times with the fuse still hooked up and never had anything happen. But I think something will happen eventually
it shoulda worked if you had it wired backwards //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
(thats why you take the fuse out when you move things)
Better yet, I disconect the battery negative, take out the fuse, and tape the end up //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I like to be safe //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
my friend did practically the same thing last night.
in the same time it took me to wire up his two amps and cut the wires to the right length, he had barely rewired the tweeters up front and attached them to the crossover.
but anyways, we turn it on and the mids/sub are playing fine, but nothing out of the tweeters. i check his wiring to the tweets, and he had taped the positive AND negative wires together, not seperately, so they were all touching and sh1t. glad we found that or i'm sure they would have crapped out shortly after. needless to say, i was the one who went back and fixed them.
Wkbdkid
Wkbdkid
San Diego
CBFryman2
BP1Fanatic
BP1Fanatic
