im stumped
audiobahnuser18
Alright guy's im stupmed i've tried everything well you probably remember me posting up a thread about this before but i can't find it so i thought i would re make one. but ok my fog lights my friend made me a powerpoint into the fuse box right to run the power from and good ground tested em numorous of time's worked fine. the next day i went to go put on my fog light's they didn't work yet the light on the switch lit up =/ , i checked all the fuses none blown , checked the ground , checked the two terminals that are running from the battery also , checked the bulbs there not blown checked both wires upfront going to the light's im getting power to them and they light up . im stumped i can't figure this one out guy's any suggestions?
21 people looked at this and not one person posted someone please help me i need these fog light's were getting a harsh winter here in Michigan plus never know when that blizzard is coming somebody any suggestions anything please help me.
you can confirm the light bulb itself is getting power? if inside the socket there is power either the bulb isnt in right, bulbs are bad, or there isnt enough power. if you arent getting power to the socket check your wires for good connection and or shorts...
alright guy's i just checked the bulb's both are getting power and they light up. so where should i check mostly for the wiring short i checked the power point to the fuse box , checked the ground , checked the way it's actually hooked to the battery . any other suggestions?
alright audio life thanks , im going to start working on it again once i get back from murrays got to bring back old rack and pinion to get core charge $$$ back:). man my ride drives like its a brand new ride put on new rack and pinion , tie rods and power steering fluid i love it:).
Well guy's i did try everything and nothing worked so i just finally took out all of the wiring to the fog light's and through the fire wall and returned em got the same light's did same way i did before work good now *knock on wood* they said it was probably a short in the actual wiring harness that u get with the fog lights but im glad there workn now:)
audiobahnuser18
audiobahnuser18
Mi
audiolife
