im in a pinch
My mags spider landing came unglued from the basket and i have no patience to get this thing back in working order what store brand glue will hold this sucker together....
nothin but ca glue bro. maybe an epoxy but I wouldnt trust it. just do it right the first time.
2part 20 min epoxy I have used it on 4 different subs and it has never failed, ca is going to be too fast and you risk making the spider brittle if it wicks into it too much, epoxy will give you the time you need to re-align everything then just place a couple pounds on the cone until it set's up!
Yep yep. I get mine at AutoZone or wherever.
Also, did you know...
The main ingredient in Super glue is cyanoacrylate (C5H5NO2, for you chemistry buffs)
actually yes I did know, ATM I have 40.00 worth of the adhesives slowly going bad(2 big bottles of the super thin 1 of the med. thick and 3 different 2part epoxy's)and nothing to glue together!
Do some recones! Lol
The "did you know" part was for the OP. As in... just go get some super glue. Lol.
well the mag has a plastic ring around the edge that the spider is glued to then the ring glues to the land, the plastic to metal is what came unglued
dumple
What's in your trunk?
dumple
Philly
SPLaudio
