Ignition Power Relay
Decipha
www.EFI Dyno Tuning.com
I would like my HU to stay powered after i removed the key and i don't want it to go off until i hit the power off button on the HU... i have an idea....
what if i ran a relay from the battery going to the ignition wire on the HU that was switched by the remote lead?
That way when i turned the key on the HU would power up and when i took the key out it would still have power until i turn the HU power off, then it wouldn't come back on until i turned the key again? Do you think this would work?
The only reason i can see why it wouldn't work is if the remote lead is powered by the memory wire inside the HU.. otherwise this should work, correct?
Decipha
Decipha
New Orleans, LA
jsloan10
