OP, I hope you're aware that wiring to any amp to .5 ohm is risky and very hard on your amp and electrical. This is why manufacturers will NOT warranty them at those loads. I'd suggest if coming up with 600$ requires significant effort for you, you probably can't afford to break a lot of amps. Just throwing it out there. Some people get away with it but just so you know, there's much more risk of breaking things.
Jesus Christ, thank you.I'll ask the question no one has, what's your electrical?
370 amp alt is only around 700-800$ then you also have 420 amp alt which is in the range of 850-950$.Jesus Christ, thank you.
I was like 'Really? Is nobody going to say it?'
OP - to give it to you straight, if you're looking for a real 5K for $600, I don't know where you're going to come up with the money for a decent electrical to support it. 5,000 watt amps aren't cheap: electrical to run 5K is a whole new can of worms.
If you have the money, awesome. If not, I'd seriously reconsider what kind of power you can afford to run right now and adjust accordingly. I'd just hate to see you running your awesome new amp down to 11.5v all the time and one day it doesn't work anymore because then, you're out of everything.
Just my two cents.
I guess I didn't see OP's "I'll have $600 next week" as a real assurance that he's got a ton of money coming in; I could be totally wrong.370 amp alt is only around 700-800$ then you also have 420 amp alt which is in the range of 850-950$.Yeah thats alot, but you can easily save this money to get what you want. You make it sound like you need 5k$ to make it happen. Not to forget 4/0 is only 10-15$ of ofc a foot so it is not much compared to having to purchase then upgrade after wasting more money.
Either way, 5k amps can be had at 750-850$ so it does not need to carry the dd m4a price tag.
He sounds pretty adamant on his power range, and I doubt he'll be able to afford it @ 2 ohms.Whats wrong with 2ohm? If you cant wire to it thats fine
My thoughts exactly, has 600$ coming next week for 5K amp (which will require another 1000$ worth of electrical upgrades to not blow it up even running it within it's design limits). 600$ isn't going to get you a reliable 5K period. 700-850$ can buy most used though, but again you'll want about a grand in electrical to properly support it.I guess I didn't see OP's "I'll have $600 next week" as a real assurance that he's got a ton of money coming in; I could be totally wrong.
Keep in mind, most decent 5Ks are a good $150 - $200 more than what OP originally wanted to spend on them. I don't know how many corners he wants to cut to make it to his goal, but this power range just isn't the place to do so. That's all I wanted to really get across.
---------- Post added at 08:42 PM ---------- Previous post was at 08:41 PM ----------
Where are you shopping for alternators? Btw the M4A is a 7k not a 5370 amp alt is only around 700-800$ then you also have 420 amp alt which is in the range of 850-950$.Yeah thats alot, but you can easily save this money to get what you want. You make it sound like you need 5k$ to make it happen. Not to forget 4/0 is only 10-15$ of ofc a foot so it is not much compared to having to purchase then upgrade after wasting more money.
