If this don't work I give up
If you want that, then a simple "quick" enclosure won't cut it. You need buy 10-15 sheets of wood and get building/testing/rebuilding/testing and keep repeating and make sure to take very clear notes. Personally, I write on each enclosure I test with in a single car so I can know exactly what everything did.
My notes normally contain...
Year/Make/Model
What sub
How much power(actual clamp)
SPL
How it sounded
Any notes I felt needed to be wrote for a later date..like box position or loading issues...or what ever.
I get it but it's not simple or quick. You know how many boxes ive been through. I found out a few things along the way. Peak is always in the mid high 40s no matter where I tune after the deadener. Subs like to be up and toward the rear, port likes to be center. That's all I got right now
---------- Post added at 10:41 PM ---------- Previous post was at 10:41 PM ----------
coming to collinsville?
No.
Have you tested with different sized enclosures? Smaller, larger?
port area alterations... internal or external ports..
subs/port up with it sealed off around the box(basic beauty panel just more rigid)....
Some times the stupidest things make the biggest differences.
---------- Post added at 09:47 PM ---------- Previous post was at 09:46 PM ----------
Within reason. Yes. Anything much bigger then 3 cubes bottoms out.
At what frequency is it bottoming out? Odds are that is user error.
It was in the high 30hz range. Nothing low
Exactly, I was getting to that point but very slowly Lol.
LosIsATool
LosIsATool
Pensacola, Florida
pro-rabbit
