if a coil read 3.0 is it a 2 or 4 ohms
That's not true at all and it will vary over frequency. Also, power compression is a very small factor for impedance rise.
^ quite obviously impedance varies substantially with frequency... but if you believe that power compression is a 'small factor' in impedance rise you are obviously clueless...
physics > > you
^ quite obviously impedance varies substantially with frequency... but if you believe that power compression is a 'small factor' in impedance rise you are obviously clueless......
physics > > you
hmmm...immacomputer...do you have a rebuttal?
Ninja its considered a Dual 4 ohm sub, the DCR is 2.8 ohms. RE uses .7's for D1's, 1.4's for D2's, and 2.8's for D4's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bonesninja
bonesninja
Lima, Ohio
Incriminator
