Sold Idq6.5 And Cx62 6.5 Midwoofers For Sale!
req
am a mod.
right. the IDQ6's never sold, so here they are again. but also i have some CX62 2 ohm midbass woofers, i modded them to remove the phase plug (which will be included with the speakers if you buy them). also i have some grills from my old NEXT component set that fit right over the cone quite nice that i will include as well. pics and description are below.
anyway, here are some pics. TS for the idqs are as follows (incredibly hard to find unless you call id lol);
model: IDQ-6
power: 150w
impedance: 4ohm
efficiency: 90db
Fs: 47hz
Qes: .28
Qms: 5.35
Qts: .27
Vas: 15L
Sd: 19.37sqin\.0125sqm
Xmax: 5.5mm
Re: 3.5ohm
Mag Wt: 30oz
V.C. Dia: 1.5in
Spkr Disp: .02cuft
box recommendations
small sealed:.125L
opt. sealed: .200L
large sealed: infinite baffle
ported: not recommended
\\IDQ6.5\\
there are a few blemishes, but these speakers are likely from around 1998. there are a few small rust spots on the basket, and some cosmetic brushes here and there, and the ID stickers are quite worn, but the surround and cone and spiders and tinsel leads are all perfectly intact. nothing effects performance that i can conceive. the pole vent has a grill on the inside so i know the coil is clean of debris. last time i hooked em up they played fine. i am listening to them right now hooked to my receiver and other than the fact the CD i used is scratched and they are free air they work great lol.
pictures.
IDQ6.5 4ohm
the cx62 is a midbass that will play to 4khz. the idq6 is a midbass\midrange, will play higher but will have less punch at the lower octaves.
least thats what i experienced with them.
still for sale.
I think you might have them mixed up
bump for great mids
no i dont have them mixed up.
the cx62 has more excursion and linear travel potential than the idq 6 making it more of a midbass than the idq6. they will both play over 4khz. the idq6 should play prolly up to 5 or better, but the cx62 should have more authority in the lower octaves than the idq will. a good starting cross over point would be around 4200hz @ 18db per octave.
cx62 = more of a midbass than a midrange
idq6 = more of a midrange than a midbass
but these are my experiences, take them or leave them, but buy my speakerz.
req
am a mod.
req
Syracuse, NY
req
