right. the IDQ6's never sold, so here they are again. but also i have some CX62 2 ohm midbass woofers, i modded them to remove the phase plug (which will be included with the speakers if you buy them). also i have some grills from my old NEXT component set that fit right over the cone quite nice that i will include as well. pics and description are below.
anyway, here are some pics. TS for the idqs are as follows (incredibly hard to find unless you call id lol);
model: IDQ-6
power: 150w
impedance: 4ohm
efficiency: 90db
Fs: 47hz
Qes: .28
Qms: 5.35
Qts: .27
Vas: 15L
Sd: 19.37sqin\.0125sqm
Xmax: 5.5mm
Re: 3.5ohm
Mag Wt: 30oz
V.C. Dia: 1.5in
Spkr Disp: .02cuft
box recommendations
small sealed:.125L
opt. sealed: .200L
large sealed: infinite baffle
ported: not recommended
\\IDQ6.5\\
there are a few blemishes, but these speakers are likely from around 1998. there are a few small rust spots on the basket, and some cosmetic brushes here and there, and the ID stickers are quite worn, but the surround and cone and spiders and tinsel leads are all perfectly intact. nothing effects performance that i can conceive. the pole vent has a grill on the inside so i know the coil is clean of debris. last time i hooked em up they played fine. i am listening to them right now hooked to my receiver and other than the fact the CD i used is scratched and they are free air they work great lol.
pictures.
IDQ6.5 4ohm
model: IDQ-6
power: 150w
impedance: 4ohm
efficiency: 90db
Fs: 47hz
Qes: .28
Qms: 5.35
Qts: .27
Vas: 15L
Xmax: 5.5mm
Re: 3.5ohm
Mag Wt: 30oz
V.C. Dia: 1.5in
Spkr Disp: .02cuft
box recommendations
small sealed:.125L
opt. sealed: .200L
\\IDQ6.5\\
pictures.
IDQ6.5 4ohm
