Sold IDQ6.5 4ohm and fullbody horn ID lense
req
am a mod.
hows it folks, i have these two items for sale, the only thing you would need for this front stage is some motors for the horn lens' and an active crossover\eq *at least 18db\oct on the horns, 24db\oct if possible. two of these compression drivers would work really well.
anyway, here are some pics. TS for the idqs are as follows (incredibly hard to find unless you call id lol);
model: IDQ-6
power: 150w
impedance: 4ohm
efficiency: 90db
Fs: 47hz
Qes: .28
Qms: 5.35
Qts: .27
Vas: 15L
Sd: 19.37sqin\.0125sqm
Xmax: 5.5mm
Re: 3.5ohm
Mag Wt: 30oz
V.C. Dia: 1.5in
Spkr Disp: .02cuft
box recommendations
small sealed:.125L
opt. sealed: .200L
large sealed: infinite baffle
ported: not recommended
\\IDQ6.5\\
there are a few blemishes, but these speakers are likely from around 1998. there are a few small rust spots on the basket, and some cosmetic brushes here and there, and the ID stickers are quite worn, but the surround and cone and spiders and tinsel leads are all perfectly intact. nothing effects performance that i can conceive. the pole vent has a grill on the inside so i know the coil is clean of debris. last time i hooked em up they played fine. i am listening to them right now hooked to my receiver and other than the fact the CD i used is scratched and they are free air they work great lol.
pictures.
IDQ6.5 4ohm
\\Full Body ID horn lens\\
Here i have some full body horns i used with my CD2 motors back in my old car. they are just longer than 11" maybe 3\4" (i dont have a ruler handy but i can measure them if requested). the are already trimmed to fit most cars, but can be trimmed further back. to fit almost any car. the motor mounts from either the top or bottom depending on what way you flip them. i would recommend mounting from the top, but most dashes do not have the room for the motor to stick upwards. there is a minor crack in the urethane plastic that i repaired with CA glue and is no longer an issie, but you can tell if you look at them closely. there is also a chip in the edge of the other driver about the length of my thumbnail (see picture) and both lens' are coated with elemental designs liquid stuff. they have a 1" diaphragm and use the 2 bolt pattern. if coupled with CD2's they should allow the horn to play down to about 800hz with a 4th order crossover. the cd1\e\pro should be around 1.2k~1.5k. i can help anyone who buys these with mounting the horns and any sort of tuning, via AIM or PM. and i can entertain inquires about fitment before they are purchased.
pictures.
full body horn lense from ID (~1998)
ALL PRICES ARE OBO
im looking for 80 shipped on the lens'. they go for 100 EACH plus shipping from image dynamics. trust me. i called them and asked and ordered mini lens' because these did NOT fit in the GTi
i am also looking 80 shipped on the IDQ6.5's. Honestly i dont know where to start with these. i recently upgraded to 8's for my midbass and i have had no use for these for some time. they use the same motor as the IDQ8 and i was thinking i could recone them, but ID has politely told me that they sadly dont have any of the parts anymore for that and recommended me their new components, bah.
if someone buys both, ill do it for 140 shipped. then its all about getting an EQ and a crossover and some motors and you should have a world class set of comps that should cost like $800
REFERENCES
caraudio.com - user name is the same, im a moderator, been there since 03, done plenty of business on the forum.
http://www.caraudio.com/forum/search.php?searchid=3475574
ebay.com
username is R3Q on ebay, done 30 transactions and have had the same account for 3+ years.
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=r3q&ftab=AllFeedback&myworld=true
if you have any questions, my PM box on CA.com or DIYMIA.com is always open. thanks.
andy
still for sale.
who needs some full body horn lenses!!! $200 new from ID, 80 used OBO from me!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i never understood horns.... what do they do exactly?
this might explain it a bit.
http://www.youtube.com/watch?v=PwSxCPQgDE8&eurl=http://www.imagedynamicsusa.com/forum/index.php?showtopic=3080
basically they are super tweeters that have a very high efficency - most tweeters fall in the range of 85db~95db with 1 watt, recorded one meter away.
the cd2 horns i have from ID can do 109db with 1 watt from 1 meter away. that means i only need to give them 10~20w and they will be louder than my 8" midbass with 250w.
they also have the big plastic lense that controls the dispersion pattern, this is what makes them cool. they play from - depending on the horn - 800hz all the way up over 20khz... and typical tweeters will only do maybe 2000hz to 20khz. so these suckers play way lower.
just a few benifits.
req
am a mod.
req
Syracuse, NY
req
