idea...
RangerDangerV2
some of you may remember my box dilemma with my mounting holes... well I had an idea of cutting out a 1 inch area of where the holes were drilled, epoxying steel block to the cutouts, drilling and tapping them, and then mounting my 18 to the blocks... do you guys see any drawbacks to this?? I would think that it would be super strong as long as the proper adhesive was used to glue the steel blocks to the box... input please.
im wondering if that area you are going to be modifying will support the weight of the sub, and the modification? i myself would create a new face/baffil to be sure for security/support
I would have to create a new box because the wood will break before the glue.... and I think that steel blocks should be strong enough...
just sounds like alot to go through rather than taking a sheet /partial sheet of new mdf/? and putting/screwing down for a new face, and cutting a hole for the sub,take like 1/2 hour to do with measuring/cutting/less work/more stability..but try it out and see how she does..im curious...you giong to be using like gorilla appoxxy or loctite?you have pics of the issue for us to look at?
ok heres the new idea.... I will take a ring of metal cut out to the shape of my subwoofer cutout, it will be about 1 inch wide... It is sort of like an oversized washer. then I will weld threaded rod to the part of the "washer where the holes are, then mount the washer to the inside of the baffle ( the washer will have to be cut in half to fit into the inside of the box) I will use this thick foam tape to stop any vibration noise between the baffle and the washer, then I will mount the sub to the baffle, use some nyloc nuts and voila sub is mounted and the weight is distributed througout the entire cutout area instead of the small contact points of the t nuts... hopefully you guys can understand this, I will post pics in my build log when I get this finished...
there is no point in that, your over engineering it
what would you reccommend for an 80 pound sub that is sitting horizontally???
---------- Post added at 07:32 PM ---------- Previous post was at 07:31 PM ----------
How about a ring of wooden studs 4+ depending on their size, wooden dowels would work well... Easy cheap and extremely strong.
I prefer steel
by using screws like I mounted my sub.
that sub weighs more then the apxx does and had zero problems.
I have thousands of pounds of steel at my house so the cost is free and it wont take more than a half hour to build... and to rebuild my box would be even more time and more money... thanks for the help though wdw
RangerDangerV2
RangerDangerV2
st cloud MN
RangerDangerV2
