never heard of ice guard raamat is the cheapest and works B-quiets brown bread is easy to use dynamat extreme and bquiet extreme work (like raamat) cascade has v-block which is easy to cut is very light but need heat gun to apply. there are many sprays from cascade stinger dyna mat rockford...my suggestion is mix a couple of items per application to save money and get the performance you want/need.. i use dynamat extreme (get a discount on it) with some vblock (tight areas) dynam mat reg on hatch floor and spray for the doors with vblock go0op on for my box =P
Ice guard is roofing material. Unless you like the smell of tar and having to replace it every time the car get's real hot. I would stay away from it. It is meant for almost flat horizontal surfaces. Not for vertical panels of the car. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
