IA lethal injection 15 or sa 15?
I would get the lethal injection just due to the fact that it has a 3" 4 layer aluminum coil and the motor force is slightly stronger so technically the LI would have more thermal power handling which I would feel safe giving it 1000-1200 daily but either sub is still a beast.
Motor force doesn't effect thermal power handling -- I also do not see any T/S specifications up for the LI yet to indicate it does indeed have a higher motor force factor. I would expect them to have a pretty similar BL^2/RE (motor force factor), actually.
I do see alot of folks under-estimating the thermal capacity of the SA line -- it is comparable to many 3" coil drivers out there in this regard thanks to the air-flow management system keeping the coil temperature in check even without alot of cone excursion //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The LI is a fine sub, though, as with the other IA drivers - very nice quality. IMO also a very good choice.
Also i heard that incriminator audio built sundowns first nightshade
09civic
09civic
Melbourne, FL
sundownz
