Ia 40.1 Vs Mtx Ta92001
quit suggesting Scottie J's amps I wont have the money for maybe a week and I want one left. To the op then the 40.1 is 3600@1 at 12volt not 14 there's a lil differance in power there
both are solid amps and will do the job at 1 ohm. like said the 40.1 will drop lowerr and allow you to put mroe power out of you up the electrrical and drop the load lower.....but if you're only sticking at 1 ohm then you should be okay either way. i personally would get the 40.1 but both are great amps
packerfan
packerfan
Beaver Dam WI
Skip01
