Sold IA 20.1, Orion HCCA 250 G4, 2 gig ipod nano. (56k warning)
go_go_thrash
squeer
First up is an Incriminator Audio 20.1: **420 shipped**
Specs: (cut and pasted from IA's site.)
Power Ratings: 1800 watts x 1 at 1 ohm
900 watts x 1 at 2 ohms
450 watts x 1 at 4 ohms
Strapable Pair: 3600 watts x 1 at 2 ohms
Protection Circuit 3 Way (Overheat, Overload, Short Circuit)
Frequency response 10Hz~350Hz
Signal/Noise Ratio 105dB
T.H.D @ 4 Ohm
Efficiency @ 4 Ohm 87%
Low Pass Filter 45Hz~300Hz
Subsonic Filter 20Hz~50Hz
Bass Boost Slope 0~18dB
Size: 10.25" Wide x 2.25" Height x 21.75" Long
Owners manual here---> http://incriminatoraudio.com/IA20.1manual.pdf
This amp is not in the best cosmetic shape, however it is fully functional. Had it tested, powers up and has output. It is missing one terminal screw, although that should not be too hard to replace. The car I bought this amp for, recently lost its engine and was not worth fixing. Buying a new car, do not want to put a HO alt in it, so the 20.1 has to go.
pics: (more pics in later post)
Next up is an Orion HCCA 250 G4 ** 260 shipped**
Power ratings at 12V and 0.1% THD:
2 x 50W @ 4 ohms
2 x 100W @ 2 ohm
2 x 200W @ 1 ohm
2 x 400W @ ½ ohm
1 x 200W @ 4 ohm bridged
1 x 400W @ 2 ohm bridged
1 x 800W @ 1 ohm bridged
THD: 0.1% (4 ohms, 20Hz ∼ 20kHz)
S/N Ratio: 100dB
Damping Factor: >400
Freq. Response: 20Hz ∼ 20kHz (±0.25dB)
Linear Bandwidth: 6Hz ∼ 50kHz (±3dB)
Fuse: 2 x 30A
Dimensions: 18" x 10.25" x 2.25" (45.7cm x 26cm x 5.7cm)
(specs taken from ampguts.realmofexcursion.com)
I have the original box for this one. In fairly good cosmetic condition normal wear and tear for an amp its age. Only one really noticable ding on the top. Bought it for a project that never came to fruition, so time to let it go.
Pics: (see later post)
Lastly a silver 2 gig ipod nano. **90 shipped**
Bought it, realized I wont use it. Have everything it came with, excepting the headphones, which I have used, so I will not be including those. Also has an inexpensive case with belt clip.
Amps will be shipped via fedex ground, double boxed, insured with signature confirmation.
Ipod will be shipped via USPS.
If you have any questions feel free to send me a PM. (sorry about my camera it sucks)
Thanks,
Gogo
go_go_thrash
squeer
go_go_thrash
Bloomington Indiana/Kent Ohio
mysilver02alty
