i won this
halfwaytohell
hmm. i have had a few of those amps
trying changing the phase on the amp. for some reason one of the ones i had there was no output when it was set at 0 but put it at 180 and the amp worked just fine. my buddy had the same issue with his powerbass amp too. we both had the asa1500's though but its worth a try?
The seller of the item is an idiot, tried saying it was a 2k watt amp. Really don't know what could be wrong with it until you open it up and test. Could just be that the seller is a moron and couldn't figure out a minor issue or just that he didn't tell u about a worse problem that will cost a good amount to fix.
i know its 1000 at 1 ohm, u see the out put its not therte. will that mess with the input part? he even says it will need a rca wire. i mean u only need the input and the out put could b left alone.
Hopefully it is just that, seems like it is. Personally i would never buy a blown amp off ebay unless i knew who was selling it or the seller had proof of exactly what was wrong(like an estimate from a shop or similar). Holy shit that amp is pretty beat up too, just hope nothing else came loose from whatever the hell he did to that amp to make it look like that.
halfwaytohell
halfwaytohell
long island
halfwaytohell
