I think this will work?
grooverider
IL
box width : 29"
height : 19"
box depth: 19"
port width : 3.8 [that will give me 36hz then become 38hz when i mount the subs?
wood thickness = .75
square port height = 17.5
square port width = 3.7
square port length = 14.55
square port length 2 =8
total port length=28.85
square port diameter =9.07977...etc
square port area= 64.75
square port volume internal : =1868.0375
square port volume displaced= 1884.3875
box volume =3.783
tuned freq= 36.039
thats with a port on the left side only, and the subs will be two audioque 12" sdc's
sound good for dnb?[drum n bass]
38-40 before or after the subs are in the box. mounting subs adds 2hz
also, is that going to be enough cubic ft for 2 AQ12's or should i make it bigger
now when you say 38hz, will that be 40 when i put the subs in? or vice versa?
I mean should i build the box to be 36 hz and then put the subs in and its 38?
grooverider
grooverider
IL
grooverider
